CGI : CONCRETE BATHROOM by Bilal Mansuri
Originally published at: https://www.ronenbekerman.com/showcase/cgi-concrete-bathroom/
IN THIS PROJECT I WANTED TO TEST OUT SOME OF THE CONCRETE MATERIALS THAT COMES INBUILT WITH VRAY 5 IN 3DS MAX.
IF YOU LOOK AT THE RESULTS, YOU’LL SEE THAT IT DID A PRETTY GOOD JOB.
ON WALLS AND FLOOR I DIDN’T EVEN USE UV MAPPING. I JUST USED THE MATERIALS WITH OPTION ENABLED : “REAL WORLD SCALE” FROM ON TOP OF THE MATERIAL BROWSER.
LITTLE ADVICE THOUGH WHEN YOU USE THE REAL WORLD SCALE OPTION MAKE SURE TO ATTACH ALL THE ELEMENTS TOGETHER LIKE UPPER PART OF THE DOOR AND BOTTOM AND UPPER PART OF WINDOW AND THEN APPLY THE MATERIAL OTHERWISE YOU WON’T EVEN UNDERSTAND WHAT IS HAPPENING WITH SOME PART AND YOUR UV IS GONNA BE MESSED UP.
THAT’S IT & KEEP CREATING BUT FIRST CHECK OUT THIS BEAUTY.
Studio: Perqued / Artist: Bilal Mansuri
